This command removes the RADIUS server configuration for a given server. Having index be in its own setting is done to remove the possibility to set the mgmt-access or netlogin setting prior to index.
| server | RADIUS server. |
| index | RADIUS server index. |
| dynamic-authorization | Specifies dynamic-authorization. |
N/A.
None.
This command was first available in ExtremeXOS 16.1.
The dynamic-authorization keyword was added in ExtremeXOS 22.1.
