Adds a server to an Automation Edge remote VXLAN Network Identifier (VNI)-device database.
database | Adds a server to a remote VNI-database. |
database_name | Adds a server to the named database. |
add | Adds a server to the database. |
server | Adds a server to the database. |
host_name | Provides hostname of the remote database server. |
ip_address | Provides the IP address of the remote server. |
port | Configures the server TCP port number. |
port_number | Specifies the server TCP port number. The default is 6,379. |
password | Specifies providing a password for the database. |
encrypted | Specifies providing an encrypted password for the database. |
encrypted_password | Provides the encrypted password. |
password | Provides the password. |
If not specified, the server TCP port number is 6,379.
N/A.
The following example adds a server at location 1.1.1.2 with password "secretpassword" to the database "database1":
# configure database database1 add server 1.1.1.2 password secretpassword
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
