Disables all anomaly checking options.
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default is disabled.
This commands disables all anomaly checking options, including IP address, UDP/TCP port, TCP flag and fragment, and ICMP anomaly checking.
This command was first available in ExtremeXOS 12.0.
