Configures the NetLogin MAC username format used when sending out for authentication to a RADIUS server.
mac | Configure Network Login settings specific to MAC. |
username | Configure username credential attributes. |
format | Configure username format. |
hyphenated | Hyphen separator (XX-XX-XX-XX-XX-XX). |
colon-separated | Colon separator (XX:XX:XX:XX:XX:XX). |
none | No separator (XXXXXXXXXXXX) (This is the default). |
No separator is the default.
The following example sets the MAC username format with colon separator:
configure netlogin mac username format colon-separated
The colon-separated option was added in ExtremeXOS 22.3.
