Displays the status of the last diagnostic test run on the switch.
| slot | Specifies which node to display diagnostic status information on. |
| slot_number | Specifies the slot number of the node on which you need to run the diagnostics. Values can be from 1 to 8. |
| boot-time | Specifies the results of the hardware checks performed at the boot time of the switch or each slot in a stack. |
N/A.
Use this command to display information from the last diagnostic test run on the switch.
To run diagnostics on a switch in a stack, you need to remove the node from the stacking mode, restart the node, and then run the diagnostics locally on the node. You can see the latest diagnostics results from the Master node of a stack after the node has rejoined the stack.
The switch displays the following diagnostic information:
If you have never run diagnostics on the switch or stack ports, the switch displays a message similar to the following:
Result: FAIL Test date run is invalid. Please run Diagnostics. Error reading diagnostics information.
This message is normal and expected if you have never run diagnostics on the switch. After you run diagnostics, you should see information about the executed test.
To run diagnostics, use the following command:
run diagnostics [extended | normal | stack-port]Depending on the software version running on your switch or your switch model, additional or different diagnostic information might be displayed. For more information, see the command run diagnostics .
The following command displays the results of the switch diagnostics:
show diagnostics
The following is sample output from this command:
Last Test Date: May-04-2006 Last Test Version: 12.3.0.1 Summary: Diagnostics Pass
When the version is unknown, Last Test Version reads “Unknown.”
The following example displays the results of boot-time diagnostics on a standalone switch:
# show diagnostics boot-time Switch: 5520-48T-ACDC Time: Thu May 23 18:47:34 2024 Component Result Details ==================== ====== ================================================= CPU PASS Memory PASS Storage PASS Power FAIL PSU-1: Powered On, PSU-2: Power Failed Mgmt interface PASS Mgmt interface present, Link Up
The following example displays the results of boot-time diagnostics on a specific stack slot:
# show diagnostics slot 2 boot-time Slot-2: 5520-48SE-ACDC Time: Thu May 23 19:04:11 2024 Component Result Details ==================== ====== ================================================= CPU PASS Memory PASS Storage PASS Power PASS PSU-1: Powered On, PSU-2: Empty Mgmt interface PASS Mgmt interface present, Link Up
This command was available in ExtremeXOS 10.1.
The boot-time option was added in version 33.1.1.
