This command configures the T3 global restart timer for all IS-IS router processes on the current virtual router.
| seconds | Specifies the restart grace period in seconds. The range is 1 to 65535 seconds. |
65535.
If the grace period expires before LSP resynchronization is complete, the virtual router sets the overload bit in LSPs that it originates.
The following command sets the restart grace period to 5000 seconds:
configure isis restart grace-period 5000
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
