Displays the configuration for all fast-reroute profiles.
| detail | Displays the profile information in verbose format. |
N/A.
None.
The following command displays summary configuration information for all fast-reroute profiles:
# show mpls rsvp-te profile fast-reroute FRR Profile Name Mode Bandwidth SPri HPri HopLmt P-BW P-Node #LSP ---------------- ------ --------- ---- ---- ------ ---- ------ ---- default_frr Detour 10 7 0 3 Dis Ena 4 prf1_frr Detour 0 7 0 3 Dis Ena 2
The following command displays detailed configuration information for all fast-reroute profiles:
# show mpls rsvp-te profile fast-reroute detail Profile Name : prf1_frr Peak Rate : 0 Kbps Committed Rate : 0 Kbps Max Burst Size : 0 Kb Setup Priority : 7 Hold Priority : 4 Hop Limit : 1 Protected BW : Off Protect Node : On #LSP References : 2 LSP / Path : pc10_lsp / p1 Profile Name : default_frr Peak Rate : 0 Kbps Committed Rate : 0 Kbps Max Burst Size : 0 Kb Setup Priority : 4 Hold Priority : 0 Hop Limit : 2 Protected BW : On Protect Node : On #LSP References : 4 LSP / Path : pc_frr_lsp / p2
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
