Displays the configuration of Inter-VR direct routes.
| direct-inter-vr | Specifies to show the configuration of direct routes leaked to a different VR. Adjacent hosts are also reachable in the specified VR. |
| ipv4 | Specifies the IPv4 address family. Only IPv4 is supported. |
| from-vr | Specifies to show only inter-VR direct route configuration for the specified leak-from-VR. If not specified, all leak-from-VRs are shown. |
| from_vr_name | Specifies the name of the leak-from-VR. |
| vr | Specifies to show only inter-VR direct route configuration for the specified leak-to-VR. If not specified, all leak-to-VRs are shown. |
| to_vr_name | Specifies the name of the leak-to-VR. |
If you do not specify a VR, the command applies to all leak-from-VRs and all leak-to-VRs.
The following example shows VLANs leaked from all VRs to all VRs:
# show iproute direct-inter-vr Inter-VR Direct IPv4 Routes Leaked To Virtual Router: VR2 Leak From VLAN Name VID Primary IP Addr. Leak From Virtual Router -------------------------------- ---- ------------------ ------------------------------ yellow 10 10.1.1.1 /24 VR1 Inter-VR Direct IPv4 Routes Leaked To Virtual Router: VR3 Leak From VLAN Name VID Primary IP Addr. Leak From Virtual Router -------------------------------- ---- ------------------ ------------------------------ yellow 10 10.1.1.1 /24 VR1 orange 11 11.1.1.1 /24 VR1 red2 20 20.1.1.1 /24 VR2
The following example displays only VLANs leaked to VR3:
# show iproute direct-inter-vr vr VR3 Inter-VR Direct IPv4 Routes Leaked To Virtual Router: VR3 Leak From VLAN Name VID Primary IP Addr. Leak From Virtual Router -------------------------------- ---- ------------------ ------------------------------ yellow 10 10.1.1.1 /24 VR1 orange 11 11.1.1.1 /24 VR1 red2 20 20.1.1.1 /24 VR2
The following example displays only VLANs leaked to all VRs from VR1:
# show iproute direct-inter-vr from-vr VR1 Inter-VR Direct IPv4 Routes Leaked To Virtual Router: VR2 Leak From VLAN Name VID Primary IP Addr. Leak From Virtual Router -------------------------------- ---- ------------------ ------------------------------ yellow 10 10.1.1.1 /24 VR1 Inter-VR Direct IPv4 Routes Leaked To Virtual Router: VR3 Leak From VLAN Name VID Primary IP Addr. Leak From Virtual Router -------------------------------- ---- ------------------ ------------------------------ yellow 10 10.1.1.1 /24 VR1 orange 11 11.1.1.1 /24 VR1
This command was first available in ExtremeXOS 32.4.
