This command displays the endpoint configured values, run-time data, and test session information.
| ipaddress | The endpoint IP address, either IPv4 or IPv6. |
| ip | Specifies the endpoint IP address. |
| port | Specifies the endpoint port. |
| udp-port | The UDP port the endpoint will listen on; range is 1025 – 65535. |
N/A.
None.
# show twamp endpoint ipaddress 19.1.1.100 port 5000
TWAMP Endpoint
Endpoint Information
Local Address: 19.1.1.100 Listening Port: 5000
Received Packets: 7948 Transmitted Packets: 7948
Active Sessions: 5
Session created on Thu Nov 13 15:41:49 2014
Peer Address: 19.1.1.2 Port: 11001
Sequence Number: 1575 Last recv'd packet: 84ms
Peer Address: 19.1.1.2 Port: 11002
Sequence Number: 1555 Last recv'd packet: 16ms
This command was first available in ExtremeXOS 16.1.
