Displays port load-sharing groups, or LAGs.
N/A.
Output from this command displays the following information:
Following is sample output displaying link aggregation on a switch:
show port sharing
Load Sharing Monitor
Config Current Agg Min Ld Share Ld Share Agg Link Link Up
Master Master Control Active Algorithm Group Mbr State Transitions
14 <2 L2 14 - R 0
L2 15 - A 1
L2 16 - R 0
17 35 Static 1 L2 17 - R 0
L2 35 Y A 1
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Minimum Active: (<) Group is down. # active links less than configured minimum
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
(L3_L4) Layer 3 address and Layer 4 port based
(custom) User-selected address-based configuration
Custom Algorithm Configuration: ipv4 L3-and-L4, xor
Custom Hash Seed: Switch MAC address (0x969BF582)
Number of load sharing trunks: 2
The LACP feature was added in ExtremeXOS 11.3.
The Health Check LAG was added in ExtremeXOS 12.1.3.
The round-robin algorithm was added in ExtremeXOS 12.5.
Support for the Min Active parameter was added in ExtremeXOS 15.7.1.
Custom hash seed information was added in ExtremeXOS 30.1.
