Renames an existing EAPS domain.
old_name | Specifies the current name of an EAPS domain. |
new_name | Specifies a new name for the EAPS domain. |
N/A.
If you use the same name across categories (for example, STPD and EAPS names), we recommend that you specify the identifying keyword as well as the actual name. If you do not use the keyword, the system might return an error message.
The following command renames EAPS domain eaps-1 to eaps-5:
configure eaps eaps-1 name eaps-5
This command was first available in ExtremeXOS 11.0.
