configure identity-management role-based-vlan
configure identity-management role-based-vlan [add | delete] ports [port_list | all]
Description
This command defines
Syntax Description
role-based vlan Associates the identity to a specific VLAN based on the identity's role.
add Adds ports to the Identity Management role-based vlan enabled portlist.
delete Deletes ports from the Identity Management role-based vlan enabled portlist.
ports Configures Identity Management role-based VLAN on ports.
port_list Configures Identity Management role-based VLAN on specified port list.
all Configures Identity Management role-based VLAN on all ports.
Default
N/A.
Usage Guidelines
Use this command to configure the role-based VLAN feature for Identity Management enabled ports. This command requires the ports to be part of a base VLAN. Enabling role-based VLAN on Identity Management enabled ports allows the identity to be placed in the correct VLAN mapped to the role as configured by the administrator.
You cannot enable the Identity Manager role-based VLAN feature on Netlogin enabled ports.
The following example configures Identity Management on ports 1-3, and 5.
# configure identity-management role-based-vlan add ports 1-3,5
This command was first available in ExtremeXOS 15.4.
Platform Availability
