Use this command to reset the maximum number of consecutive seconds an authenticated session may be idle before termination of the session to the default value of 300 seconds.
| idle-timeout | Clear timeout for an idle session. |
| session-timeout | Clear timeout for an active session. |
| dot1x | IEEE 802.1X Port-based network access control. |
| mac | MAC authentication. |
| web-based | Web-based authentication. |
| convergence-endpoint | Convergence-endpoint authentication. |
300
If no authentication type is specified, the idle timeout value is returned to 300 seconds for all authentication types.
unconfigure netlogin idle-timeout mac
This command was first available in ExtremeXOS 16.1.
The convergence-endpoint option was added in ExtremeXOS 22.5.
