Displays LLDP configuration information for the specified port or ports.
Use the detailed keyword to display the configured VLANs on the port and the enabled VLAN-specific TLVs.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| detailed | Shows information on the configured VLANs on the port. |
N/A.
Use the detailed variable to display information regarding configured VLANs on the ports and any enabled VLAN-specific TLVs.
The following example displays LLDP configuration information for the switch:
# show lldp LLDP transmit interval : 30 seconds LLDP transmit hold multiplier : 4 (used TTL = 120 seconds) LLDP transmit delay : 2 seconds LLDP SNMP notification interval : 5 seconds LLDP reinitialize delay : 2 seconds LLDP-MED fast start repeat count : 4 LLDP local management address : VLAN Chicago (10.127.2.30) LLDP Port Configuration: Port Rx Tx SNMP --- Optional enabled transmit TLVs -- Mode Mode Notification LLDP 802.1 802.3 MED AvEx DCBX =============================================================================== 1 Enabled Enabled -- --D-- --- ---- ---- ---- IB 2 Enabled Enabled -- --D-- --- ---- ---- ---- IB =============================================================================== Notification: (L) lldpRemTablesChange, (M) lldpXMedTopologyChangeDetected LLDP Flags : (P) Port Description, (N) System Name, (D) System Description (C) System Capabilities, (M) Mgmt Address 802.1 Flags : (P) Port VLAN ID, (p) Port & Protocol VLAN ID, (N) VLAN Name 802.3 Flags : (M) MAC/PHY Configuration/Status, (P) Power via MDI (+) Power via MDI with DLL Classification for PoE+, (L) Link Aggregation, (F) Frame Size MED Flags : (C) MED Capabilities, (P) Network Policy, (L) Location Identification, (p) Extended Power-via-MDI AvEx Flags : (P) PoE Conservation Request, (C) Call Server, (F) File Server (Q) 802.1Q Framing DCBX Flags : (I) IEEE 802.1Qaz DCBX, (B) Baseline v1.01 DCBX
The following example includes detailed information on the LLDP configuration for port 1:1:
# show lldp port 1:1 detailed LLDP transmit interval : 30 seconds LLDP transmit hold multiplier : 4 (used TTL = 120 seconds) LLDP transmit delay : 2 seconds LLDP SNMP notification interval : 5 seconds LLDP reinitialize delay : 2 seconds LLDP-MED fast start repeat count : 4 LLDP local management address : VLAN Chicago (10.127.2.30) LLDP Port Configuration: Port Rx Tx SNMP --- Optional enabled transmit TLVs -- Mode Mode Notification LLDP 802.1 802.3 MED AvEx DCBX =============================================================================== 1:1 Enabled Enabled -- --D-- --- ---- CLP- ---- IB VLAN: Default ----- --- ---- ---- ---- VLAN: voice ----- --- ---- ---- ---- AvEx Call-Server: IP Address(es)=10.0.0.20, 10.0.0.21 AvEx File-Server: IP Address(es)=10.0.0.20, 10.0.0.21, 10.0.0.22 AvEx 802.1Q Framing: Mode=tagged MED LCI: Location Format=ECS ELIN based 1234567890 MED Policy: Application=voice VLAN=voice, DSCP=40 DCBX: Priority 4, iSCSI DCBX: Priority 3, FCoE DCBX: Priority 3, FIP =============================================================================== Notification: (L) lldpRemTablesChange, (M) lldpXMedTopologyChangeDetected LLDP Flags : (P) Port Description, (N) System Name, (D) System Description (C) System Capabilities, (M) Mgmt Address 802.1 Flags : (P) Port VLAN ID, (p) Port & Protocol VLAN ID, (N) VLAN Name 802.3 Flags : (M) MAC/PHY Configuration/Status, (P) Power via MDI (L) Link Aggregation, (F) Frame Size MED Flags : (C) MED Capabilities, (P) Network Policy, (L) Location Identification, (p) Extended Power-via-MDI AvEx Flags : (P) PoE Conservation Request, (C) Call Server, (F) File Server (Q) 802.1Q Framing DCBX Flags : (I) IEEE 802.1Qaz DCBX, (B) Baseline v1.01 DCBX
The information on fast-start repeat count, MED, AvEx, and notification was added in ExtremeXOS 11.5.
An additional flag was added for PoE+ in ExtremeXOS 12.5.
The display was updated for DCBX in ExtremeXOS 12.6.
Management IP address information was added in ExtremeXOS 22.4.
