Disables the split horizon algorithm for RIPng.
vlan-name | Specifies an IPv6 configured VLAN. |
tunnel_name | Specifies an IPv6 tunnel. |
all | Specifies all interfaces. |
Enabled.
Split horizon is a scheme for avoiding problems caused by including routes in updates sent to the router from which the route was learned. Split horizon omits routes learned from a neighbor in updates sent to that neighbor.
The following command disables the split horizon algorithm for RIPng:
disable rip splithorizon
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
