Configures a port not to receive MVR multicast streams.
| vlan-name | Specifies a VLAN name. |
| port-list | A list of ports or slots and ports. |
N/A.
This command is used to delete a group of virtual ports for multicast forwarding through MVR. After using this command, the ports revert to the default forwarding rules.
The following example deletes the ports 1:1 and 1:2 of VLAN v1 to MVR for forwarding:
configure mvr vlan v1 delete receiver port 1:1-1:2
This command was first available in ExtremeXOS 11.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.1.1 Licensing Guide document.
