This command is a macro command that can be used to disable all AVB protocols globally on the switch. It is equivalent to issuing the following three commands:
disable mvrp
disable msrp
disable network-clock gptp
| avb | Audio Video Bridging |
Disabled.
Use this command to disable all AVB protocols globally on the switch.
disable avb
This command was first available in ExtremeXOS 15.3.
This command is available on all ExtremeSwitching Universal switches that support the AVB feature.
