Configures the LLDP port to advertise or not to advertise Data Center Bridging Exchange (DCBX) information to its neighbors.
all |
Specifies all ports on the switch. |
port_list |
Specifies one or more ports or slots and ports. |
advertise |
Specifies to send the information to neighbors. |
no-advertise |
Specifies not to send the information to neighbors. |
ieee |
Specifies the DCBX protocol defined in IEEE 802.1Qaz. |
baseline |
Specifies the DCBX protocol known as Baseline Version 1.01, which was defined before IEEE 802.1Qaz. |
No advertisement for both DCBX protocols.
If you do not specify a protocol with this command, the advertise option enables advertisement for the IEEE 802.1Qaz protocol, and the no-advertise option disables advertisement for both protocols.
configure lldp ports 1:5 advertise vendor specific dcbx
configure lldp ports 2:1 advertise vendor specific dcbx baseline
configure lldp ports all no-advertise vendor specific dcbx
This command was first available in ExtremeXOS 12.6.
