Configures an anomaly rate-based notification feature.
| value | Specifies the number of events for the trigger. |
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default is 1.
This is a paired command with configure ip-security anomaly-protection notify trigger off that configures an anomaly rate-based notification feature. The anomaly notification is automatically triggered if the rate of anomaly events is greater than the configured ON value, and the notification is disabled if the rate falls below the value set in the configure ip-security anomaly-protection notify trigger off command.
The command takes effects after the anomaly notification is enabled.
The value set in ON must be greater than or equal to the value set in OFF.
This command was first available in ExtremeXOS 12.0.
