Displays the status of MAC locking on one or more ports
| port_list | Specifies one or more ports or slots and ports. |
N/A
If you do not specify a port, MAC locking status is displayed for all ports.
In MLAG, the mac-locking entries shown in this command's output are only natively learned FDB entries on the switch.
The following example displays MAC locking status for all ports.
show mac-locking
MAC locking is globally disabled.
Port MAC Trap Log FA Limit Link Max Max Last Violating
Lock Thr|Viol Thr|Viol Aging Action Down Stc FA MAC Address
Stat Cfg|Stat Action
1 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
2 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
3 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
4 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
5 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
6 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
7 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
8 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
9 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
10 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
11 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
12 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
13 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
14 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
15 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
16 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
17 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
18 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
19 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
20 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
21 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
22 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
23 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
24 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
25 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
26 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
27 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
28 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
29 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
30 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
31 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
32 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
33 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
34 dis off|off off|off dis ena|ena clear 64 600 00:00:00:00:00:00
Legend:
Stat - Status Thr|Viol - Threshold | Violation
Max Stc - Max Static Count Max FA - Max First-Arrival Count
dis - Disabled ena - Enabled
retain - Retain MACs clear - Clear MACs
Limit Action Cfg - If port should be disabled when learnt limit is exceeded
dis - Port to be disabled when learn limit is exceeded
ena - Port to remain enabled when learn limit is exceeded
Limit Action Stat - Port status on exceeding learn limit
This command was first available in ExtremeXOS 15.7.1.
