enable ospf
enable ospf
Description
Enables the OSPF process for the router.
Syntax Description
This command has no keywords or arguments.
Default
N/A.
Usage Guidelines
Not applicable.
The following command enables the OSPF process for the router:
enable ospf
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
