This command is used to add/delete the local MEP for a given CFM segment.
segment_name |
Alphanumeric string identifying the segment name. |
frame-loss |
Y.1731 Ethernet frame loss measurement. |
N/A.
The MEP with the given MEP ID should already be created in the system. The domain and association for the segment should be configured before executing this command. If the domain and association are not configured, the command throws an error.
Configuring of local MEP is mandatory to start the Frame Loss measurements.
configure cfm segment cs2 add mep 3 configure cfm segment cs2 delete mep 3
This command was first available in ExtremeXOS 15.1.
