Displays summary EAPS counter information.
| eapsDomain | Specifies the name of an EAPS domain. The switch displays counter information for only that domain. |
| global | Displays EAPS counter information when the events counted are not applicable to any specific EAPS domain. |
N/A.
If you specify the name of an EAPS domain, the switch displays counter information related to only that domain. If you specify the global keyword, the switch displays EAPS counter information when the events counted are not applicable to any specific EAPS domain. The output displayed is for all configured EAPS domains, not just one specific EAPS domain.
Viewing and maintaining statistics on a regular basis allows you to see how well your network is performing. If you keep simple daily records, you will see trends emerging and notice problems arising before they cause major network faults.
| Field | Description |
Rx-Health |
Indicates the EAPS domain received EAPS Health PDUs. |
Rx-RingUp-FlushFdb |
Indicates the EAPS ring is up, and the EAPS domain received EAPS RingUp-FlushFdb PDUs to flush the FDB. |
Rx-RingDown-FlushFdb |
Indicates the EAPS ring is down, and the EAPS domain received EAPS RingDown-FlushFdb PDUs to flush the FDB. |
Rx-Link-Down |
Indicates the EAPS domain received EAPS Link-Down PDUs and took down the link. |
Rx-Flush-Fdb |
Indicates the EAPS domain received EAPS Flush-Fdb PDUs and flushed the FDB. |
Rx-Suspend-Prefwd-Timer |
Indicates the EAPS domain received EAPS Suspend-Preforward-Timer PDUs. |
Rx-Query-Link-Status |
Indicates the EAPS domain received EAPS Query-Link-Status PDUs. |
Rx-Link-Up |
Indicates the EAPS domain received EAPS Link-Up PDUs and brought the link back up. |
Rx-Unknown |
Indicates the EAPS domain dropped unknown EAPS PDUs. |
Rx-Another-Master |
Indicates the EAPS domain dropped EAPS PDUs because there is another Master switch in the same EAPS domain. |
Rx-Unconfigured-Port |
Indicates the EAPS domain dropped EAPS PDUs because the ingress port is not configured to be a ring port for the EAPS domain and the corresponding control VLAN. |
Rx-Health-Pdu-Pri-Port |
Indicates the EAPS domain dropped EAPS Health PDUs because the primary port received them instead of the secondary port. NOTE: The secondary port of the Master switch must receive EAPS Health PDUs, not the primary port. |
Tx-Health |
Indicates the EAPS domain sent EAPS Health PDUs. |
Tx-RingUp-FlushFdb |
Indicates the EAPS ring is up, and the EAPS domain sent EAPS RingUp-FlushFdb PDUs to flush the FDB. |
Tx-RingDown-FlushFdb |
Indicates the EAPS ring is down, and the EAPS domain sent EAPS RingDown-FlushFdb PDUs to flush the FDB. |
Tx-Link-Down |
Indicates the EAPS domain sent EAPS Link-Down PDUs because the link went down. |
Tx-Flush-Fdb |
Indicates the EAPS domain sent EAPS Flush-Fdb PDUs because the FDB needs to be flushed. |
Tx-Suspend-Prefwd-Timer |
Indicates the EAPS domain sent EAPS Suspend-Preforward-Timer PDUs. |
Tx-Query-Link-Status |
Indicates the EAPS domain sent EAPS Query-Link-Status PDUs. |
Tx-Link-Up |
Indicates the EAPS domain sent EAPS Link-Up PDUs and the link is up. |
Tx-Unknown |
Indicates the number of unknown EAPS PDUs sent by the EAPS domain. NOTE: Unknown EAPS PDUs can be a new type of PDU that the switch does not track in the sending routine. |
Tx-Transmit-Err |
Indicates the number of EAPS PDUs the EAPS domain was unable to send because of an error. |
Fw-Link-Down |
Indicates the number of EAPS Link-Down PDUs received by the EAPS domain and forwarded in slow path. |
Fw-Flush-Fdb |
Indicates the number of EAPS Flush-Fdb PDUs received by the EAPS domain and forwarded in slow path. |
FW-Query-Link-Status |
Indicates the number of EAPS Query-Link-Status PDUs received by the EAPS domain and forwarded in slow path. |
Fw-Unknown |
Indicates the number of unknown EAPS PDUs forwarded in slow path. NOTE: Unknown EAPS PDUs can be a new type of PDU that the switch does not track in the forwarding routine. |
Fw-Transmit-Er |
Indicates the number of EAPS PDUs the EAPS domain was unable to forward in slow path because of an error. |
Rx and Fw counters—If a PDU is received, processed, and consumed, only the Rx counter increments. If a PDU is forwarded in slow path, both the Rx counter and Fw counter increment.
Rx-Failed |
Indicates an error occurred when receiving packets from the Layer 2 forwarding engine. |
Rx-Invalid-Vlan-Intf |
Indicates that the VLAN interface for the incoming VLAN cannot be found. |
Rx-Undersize-Pkt |
Indicates the length of the packet is less than the length of the header. |
Rx-Invalid-8021Q-Tag |
Indicates the VlanTypeLength field in the Ethernet header does not match the default Ethernet value for the 802.1Q tag. |
Rx-Invalid-SNAP-Type |
Indicates an invalid Subnetwork Access Protocol (SNAP) value in the Ethernet header. |
Rx-Invalid-OUI |
Indicates the Organizational Unique Identifier (OUI) value in the Ethernet header does not match 00:E0:2B. |
Rx-EEP-Unsupported-Version |
Indicates an unsupported Extreme Encapsulation Protocol (EEP) version. The EEP version should be 1. |
Rx-EEP-Invalid-Length |
Indicates the length of the EEP header is greater than the length of the packet. |
Rx-EEP-Checksum-Invalid |
Indicates the EEP checksum is invalid. |
Rx-Domain-Invalid |
Indicates the control VLAN‘s incoming PDU is not associated with an EAPS domain. |
Rx-Lif-Invalid |
Indicates that EAPS is unable to determine the logical interface (LIF) for the ingress port. |
Rx-Lif-Down |
Indicates the LIF for the ingress port is in the Down state. |
Tx-Failed |
Indicates an error occurred when sending packets to the Layer 2 forwarding engine. |
The following command displays the counters for a specific EAPS domain named eaps1:
show eaps counters eaps1
The following is sample output from this command:
Counters for EAPS domain: eaps1 Rx Stats Rx-Health : 0 Rx-Ringup-Flushfdb : 0 Rx-Ringdown-Flushfdb : 0 Rx-Link-Down : 0 Rx-Flush-Fdb : 0 Rx-Suspend-Prefwd-Timer : 0 Rx-Query-Link-Status : 0 Rx-Link-Up : 0 Rx Dropped Rx-Unknown : 0 Rx-Another-Master : 0 Rx-Unconfigured-Port : 0 Rx-Health-Pdu-Pri-Port : 0 Tx Stats Tx-Health : 5011 Tx-Ringup-Flushfdb : 0 Tx-Ringdown-Flushfdb : 0 Tx-Link-Down : 0 Tx-Flush-Fdb : 0 Tx-Suspend-Prefwd-Timer : 0 Tx-Query-Link-Status : 3342 Tx-Link-Up : 0 Tx Dropped Tx-Unknown : 0 Tx-Transmit-Err : 0 Fw Stats Fw-Link-Down : 0 Fw-Flush-Fdb : 0 Fw-Query-Link-Status : 0 Fw Dropped Fw-Unknown : 0 Fw-Transmit-Err : 0
The following command displays the global EAPS counters:
show eaps counters global
Global counters for EAPS: Rx-Failed : 0 Rx-Invalid-Vlan-Intf : 0 Rx-Undersize-Pkt : 0 Rx-Invalid-SNAP-Type : 0 Rx-Invalid-OUI : 0 Rx-EEP-Unsupported-Version : 0 Rx-EEP-Invalid-Length : 0 Rx-EEP-Checksum-Invalid : 0 Rx-Domain-Invalid : 0 Rx-Failed : 0 Rx-Lif-Invalid : 0 Rx-Lif-Down : 0 Tx-Failed : 0
This command was first available in ExtremeXOS 11.6.
