This command configures the LACP fallback timeout value in seconds.
| lacp | LACP (Link Aggregation Control Protocol). |
| fallback | Allow single member port with lowest value priority to be added to the aggregator if LACP PDUs are not received within timeout. |
| timeout | Timeout used to determine how long to wait for LACP PDUs before entering fallback. |
| seconds | Fallback timeout in seconds. Range 0-100. |
60 seconds.
* # show lacp lag 17 detail
Lag Actor Actor Partner Partner Partner Agg Actor
Sys-Pri Key MAC Sys-Pri Key Count MAC
17 0 0x03f9 00:00:00:00:00:00 0 0x0000 1 00:04:96:6d:55:13
Enabled : Yes
LAG State : Up
Unack count : 0
Wait-for-count : 0
Current timeout : Long
Activity mode : Active
Defaulted Action : Delete
Fallback : Enabled
Fallback timeout : 40 seconds
Receive state : Enabled
Transmit state : Enabled
Minimum active : 1
Selected count : 1
Standby count : 0
LAG Id flag : Yes
S.pri:0 , S.id:00:04:96:6d:55:13, K:0x03f9
T.pri:0 , T.id:00:00:00:00:00:00, L:0x0000
Port list:
Member Port Rx Sel Mux Actor Partner
Port Priority State Logic State Flags Port
17 10 Initialize Unselected Detached A-G----- 0
18 5 Initialize Fallback Collect-Dist A-GSCD-- 1018
19 5 Idle Unselected Detached -------- 0
Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization
C-Collecting, D-Distributing, F-Defaulted, E-Expired
This command was first available in ExtremeXOS 21.1.
