enable rip
enable rip
Description
Enables RIP for the whole router.
Syntax Description
Default
Disabled.
Usage Guidelines
RIP has a number of limitations that can cause problems in large networks, including:
  • A limit of 15 hops between the source and destination networks.
  • A large amount of bandwidth taken up by periodic broadcasts of the entire routing table.
  • Slow convergence.
  • Routing decisions based on hop count; no concept of link costs or delay.
  • Flat networks; no concept of areas or boundaries.
The following command enables RIP for the whole router:
# enable rip
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
Platform Availability
This command is available on all platforms with an Edge, Advanced Edge, or Core license.
