disable mac-lockdown-timeout ports
disable mac-lockdown-timeout ports [all | port_list]
Description
Disables the MAC address lock down timeout feature for the specified port or group of ports or for all ports on the switch.
Syntax Description
all Specifies all ports.
port_list Specifies one or more ports or slots and ports.
Default
By default, the MAC address lock down feature is disabled.
Usage Guidelines
If you disable the MAC lock down timer on a port, existing MAC address entries for the port will time out based on the FDB aging period.
The following command disables the MAC address lock down timer set for ports 2:3 and 2:4:
disable mac-lockdown-timeout ports 2:3, 2:4
This command was first available in ExtremeXOS 11.6.
Platform Availability
