enable netlogin reauthentication-on-refresh
Description
Enables network login reauthentication on refresh.
Syntax Description
Default
Disabled.
Usage Guidelines
The web-based Netlogin client's session is periodically refreshed by sending a HTTP request which acts as a keep-alive without actually re-authenticating the user's credentials with the back-end RADIUS server or local database. If reauthenticate-on-refresh is enabled, re-authentication occurs with the session refresh.
Platform Availability
