This command configures the user privilege level needed to view diagnositc results.
| privilege | Configure minimum privilege level needed to view diagnostic results. |
| admin | Only admin (read-write) accounts can view diagnostic results. |
| user | User (read-only) accounts can view diagnostic results also (default). |
User.
Use this command to configure the privilege level required to view diagnostic results.
This command was first available in ExtremeXOS 16.1.
