Deletes a static multicast address from the multicast routing table.
| default | Specifies default gateway. |
| source-net | Specifies an IP address/mask length. |
| mask-len | Mask length for the IP multicast source's subnet. Range is 1–32. |
| mask | Specifies a subnet mask. |
| protocol | Unicast routing protocol that is to be used for route learning. |
| rpf-address | Next hop through which the multicast source can be reached. |
| vr-name | Specifies the virtual router to which the route is added. |
vr-name is the VR of the current CLI context.
This command allows you to delete an existing multicast static route. It allows you to configure congruent topology for unicast and multicast packets and traffic.
The following example deletes a multicast static route:
configure ipmroute delete 192.168.0.0/16 192.75.0.91
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
