Displays the configured keychains.
| keychain_name | Defines a name for the new keychain. The range is 1-31. |
| detail | Specifies a detailed output. |
N/A.
Use this command to display the configured keychains.
The following is an example of the command's output with no specified keychain name:
# show keychain
# # Accept
Name Keys Clients Tolerance
auth1 3 2 10s
auth2 4 0 0s
ospfv3-keys 6 1 0s
The following is an example of the command's output with a keychain name of keys1:
show keychain ospfv3-keys1 Accept Tolerance : 0s Number of Clients: 1 Key ID Algorithm Start Time End Time Duration ------ ------------ -------------------- -------------------- ---------- +1 HMAC-SHA-256 2021-06-01 00:00:00 2021-07-01 00:00:00 2592000s 2 HMAC-SHA-512 2021-07-01 00:00:00 2021-08-01 00:00:00 2678400s 3 HMAC-SHA-256 2021-08-01 00:00:00 2021-09-01 00:00:00 2678400s Legend: (*) Active Key, (+) Selected Key, (Z) Time is in UTC.
The following is an example of the command's output with a keychain name of keys1 with detail specified:
show keychain ospfv3-keys1 detail Accept Tolerance : 0s Number of Clients : 1 Clients : ospfv3-2 Key ID : +1 Encrypted Key String: #$y2O9VBgcxFr4NkVKnadBL5y1s9cvnA== Algorithm : HMAC-SHA-256 Start Time : 2021-06-01 00:00:00 End Time : 2021-07-01 00:00:00 Duration : 2592000s Key ID : 2 Encrypted Key String: #$f4Vtob4C5TdAs9Qf0w/pbB8RecE9vA== Algorithm : HMAC-SHA-512 Start Time : 2021-07-01 00:00:00 End Time : 2021-08-01 00:00:00 Duration : 2678400s Key ID : 3 Encrypted Key String: #$bvE/wSf/6sztYL4wJw8ZUTWjJT2ZWw== Algorithm : HMAC-SHA-256 Start Time : 2021-08-01 00:00:00 End Time : 2021-09-01 00:00:00 Duration : 2678400s Legend : (*) Active Key, (+) Selected Key.
This command was first available in ExtremeSwitching 31.3.
