This command configures one HTTP Online Certificate Status Protocol (OCSP) override URL for RADIUS TLS servers.
| tls | Specifies Transport Layer Security (TLS). |
| ocsp | Specifies the OCSP attribute. |
| override | Specifies to override the OCSP server in the AuthorityInformationAccess section of a RADIUS TLS server's certificate. |
| url | Specifies the URL of the OCSP override server. Default port is 80. |
| none | Specifies to remove the OCSP override URL configuration (default). |
None.
Only HTTP is supported with either FQDN or IP.
The following example configures an override URL of http://radiusocsp:2021:
# configure radius tls ocsp override http://radiusocsp:2021
This command was first available in ExtremeXOS 32.2.
