unconfigure netlogin vlan
Description
Unconfigures the VLAN for network login.
Syntax Description
Default
N/A.
Usage Guidelines
This command unconfigures the VLAN used for unauthenticated clients. One VLAN needs to be configured per VR. To change the VLAN, network login needs to be disabled.
The following command unconfigures the network login VLAN:
This command was first available in ExtremeXOS 11.1.
Platform Availability
