Restores the default order of database authentication protocols to use.
| mac | Specifies the MAC address to add. |
| mask | Specifies the number of bits to use for the mask. |
| default | Specifies the default entry. |
| encrypted | Used to display encrypted form of password in configuration files. Do not use. |
| password | Specifies the password to send for authentication. |
| ports | Specifies the port or port list to use for authentication. |
By default, the authentication order is RADIUS, local-user database.
Use this command to restore the default configuration order for the database authentication protocols. For details, see the Switch Engine v33.1.1 Licensing Guide document.
The following command sets the database authentication order to RADIUS, local user database for MAC-based authentication:
unconfigure netlogin mac authentication database-order
This command was first available in ExtremeXOS 12.0.
