Configures the election algorithm on the switch.
| esrpDomain | Specifies an ESRP domain name. |
| ports > track > priority | Specifies that this ESRP domain should consider election factors in the following order: Active ports, tracking information, ESRP priority. |
| ports > track > priority > mac | Specifies that this ESRP
Active ports, tracking information, ESRP priority, MAC
address. Note: This is the default election algorithm for
standard mode.
| priority > mac | Specifies that this ESRP domain should consider election factors in the following order: ESRP priority, MAC address. |
| priority > ports > track > mac | Specifies that this ESRP domain should consider election factors in the following order: ESRP priority, active ports, tracking information, MAC address. |
| priority > track > ports > mac | Specifies that this ESRP domain should consider election factors in the following order: ESRP priority, tracking information, active ports, MAC address. |
| sticky > ports > track > priority | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, active ports, tracking information, ESRP priority. |
| sticky > ports > track > priority > mac | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, active ports, tracking information, ESRP priority, MAC address. |
| sticky > ports > weight > track > priority > mac | Specifies that this ESRP
Stickiness, active ports, port weight, tracking information, ESRP
priority, MAC address. Note: Beginning with ExtremeXOS 11.1 and
later, this is the default election algorithm for extended
mode.
| sticky > priority > mac | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, ESRP priority, MAC address. |
| sticky > priority > ports > track > mac | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, ESRP priority, active ports, tracking information, MAC address. |
| sticky > priority > track > ports > mac | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, ESRP priority, tracking information, active ports, MAC address. |
| sticky > track > ports > priority | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, tracking information, active ports, ESRP priority. |
| sticky > track > ports > priority > mac | Specifies that this ESRP domain should consider election factors in the following order: Stickiness, tracking information, active ports, ESRP priority, MAC address. |
| track > ports > priority | Specifies that this ESRP domain should consider election factors in the following order: Tracking information, active ports, ESRP priority. |
| track > ports > priority > mac | Specifies that this ESRP domain should consider election factors in the following order: Tracking information, active ports, ESRP priority, MAC address. |
In extended mode, the default election algorithm is sticky > ports > weight > track > priority > mac.
In standard mode, the default election algorithm is ports > track > priority > mac.
The election algorithm must be the same on all switches for a particular ESRP domain. The election algorithms that use sticky are and weight are available in extended mode only.
In ExtremeXOS 11.0, the extended mode default election algorithm is: sticky > ports > track > priority > mac > weight. This election algorithm is not supported in ExtremeXOS 11.1.
The ports-track-priority or track-ports-priority options can be used to ensure that there is no failback if the original Master recovers (the Master has the same ports, tracks and priority, but a higher MAC).
Any of the options with sticky can also be used to ensure that there is no failback if the original master recovers. With sticky, if an event causes the ESRP master to failover, ESRP assigns the new master with the sticky count of 1. After sticky is set on the master, regardless of changes to its neighbor‘s election algorithm, the new master retains its position. For example, adding active ports to the slave does not cause the new master to failback to the original master, even if the slave has more active ports than the master. Sticky algorithms provide for fewer network interruptions than non-sticky algorithms. Sticky is set on the master switch only.
ESRP re-election can occur if sticky is set on the master and a local event occurs. During this time, if the current master has lower election parameters, the backup can become the new master.
If a switch is master, it actively provides Layer 3 routing services to other VLANs, and Layer 2 switching between all the ports of that VLAN. Additionally, the switch exchanges ESRP packets with other switches that are in slave mode.
If a switch is in slave mode, it exchanges ESRP packets with other switches on that same VLAN. When a switch is in slave mode, it does not perform Layer 3 routing or Layer 2 switching services for the VLAN.
ESRP uses the default election policy for extended mode. If you have an ESRP domain operating in standard mode, the domain ignores the sticky and weight algorithms. To change the election algorithm, you must first disable the ESRP domain and then configure the new election algorithm. If you attempt to change the election algorithm without disabling the domain first, an error message appears.
To disable the ESRP domain, use the following command:
disable esrp {esrpDomain}To modify the election algorithm, use the following command:
configure esrp esrpDomain election-policy [ports > track > priority | ports > track > priority > mac | priority > mac | priority > ports > track > mac | priority > track > ports > mac | sticky > ports > track > priority | sticky > ports > track > priority > mac | sticky > ports > weight > track > priority > mac | sticky > priority > mac | sticky > priority > ports > track > mac | sticky > priority > track > ports > mac | sticky > track > ports > priority | sticky > track > ports > priority > mac | track > ports > priority | track > ports > priority > mac]If you attempt to use an election algorithm not supported by the switch, an error message similar to the following appears:
ERROR: Specified election-policy is not supported! Supported Policies: 1. sticky > ports > weight > track > priority > mac 2. ports > track > priority 3. sticky > ports > track > priority 4. ports > track > priority > mac 5. sticky > ports > track > priority > mac 6. priority > mac 7. sticky > priority > mac 8. priority > ports > track > mac 9. sticky > priority > ports > track > mac 10. priority > track > ports > mac 11. sticky > priority > track > ports > mac 12. track > ports > priority 13. sticky > track > ports > priority 14. track > ports > priority > mac 15. sticky > track > ports > priority > mac
The following example configures the election algorithm to use tracking information as the first criteria for determining the ESRP master switch for ESRP domain esrp1:
configure esrp esrp1 election-policy track > ports > priority > mac
This command was first available in ExtremeXOS 11.0.
The default election algorithm for extended mode was updated to sticky > ports > weight > track > priority > mac, and the weight election factor was used in ExtremeXOS 11.1. The sticky > ports > track > priority > mac > weight election algorithm is not supported in ExtremeXOS 11.1.
