Shows NTP-related statistics about a specific NTP server.
| ip_address | Server or peer IP address. |
| host_name | Server or peer name. |
| vr | Specifies information for a particular virtual router. |
| vr_name | Name of the particular virtual router. If not specified, VR of current command context is used. |
N/A.
N/A.
The following command shows NTP-related statistics about the NTP server called “1.us.pool.ntp.org”:
Switch# show ntp association 1.us.pool.ntp.org statistics Remote Host : 1.us.pool.ntp.org Local Interface : 10.45.203.74 Time Last Received : 40 second Time Until Next Send: 27 second Reachability Change : 849 second Packets Sent : 18 Packets Received : 18 Bad Authentication : 0 Bogus Origin : 0 Duplicate : 0 Bad Dispersion : 0 Bad Reference Time : 0 Candidate Order : 4 Peer Flags : Config, Broadcast Client, Initial Burst
The following command shows NTP-related statistics for the NTP server at 128.138.141.172 for virtual router "VR-Mgmt":
# show ntp association 128.138.141.172 statistics vr "VR-Mgmt" VR Name : VR-Mgmt Remote Host : 128.138.141.172 Local Interface : 10.127.2.180 Time Last Received : 146 seconds Time Until Next Send: 113 seconds Reachability Change : 2564 seconds Packets Sent : 86 Packets Received : 86 Bad Authentication : 0 Bogus Origin : 0 Duplicate : 0 Bad Dispersion : 0 Bad Reference Time : 0 Candidate Order : 6
This command was first available in ExtremeXOS 12.7.
Virtual router keyword added in ExtremeXOS 22.2
