Configures the number of times a slot can be restarted on a failure before it is shut down.
| slot_number | Specifies the slot number. |
| num_restarts | Specifies the number of times the slot can be restarted. The range is from 0 to 10,000. |
The default is 5.
This command allows you to configure the number of times a slot can be restarted on a failure before it is shut down. If the number of failures exceeds the restart-limit, the module goes into a “Failed” state. If that occurs, use the disable slot and enable slot commands to restart the module.
The following command configures slot 2 on the switch to be restarted up to 3 times upon a failure:
configure slot 2 restart-limit 3
This command was first available in ExtremeXOS 12.0.
This command is available only on SummitStack.
