Disables ARP validation for the specified VLAN and member ports.
| vlan_name | Specifies the name of the VLAN to which this rule applies. |
| dynamic | Configuration options for dynamically created VLANs. |
| all | Specifies all ports. |
| ports | Specifies one or more ports. |
By default, ARP validation is disabled.
Use this command to disable ARP validation.
To display information about ARP validation, use the following command:
show ip-security arp validation {vlan} vlan_nameThe following command disables ARP validation on port 1:1 of the VLAN valid:
disable ip-security arp validation vlan valid ports 1:1
This command was first available in ExtremeXOS 11.6.
Dynamic VLAN option added in ExtremeXOS 30.2.
