Enables MVRP globally on a switch.
| mvrp | Multiple VLAN Registration Protocol. |
Disabled.
Use this command to enable MVRP globally on a switch. MVRP is run on the MVRP enabled ports only if the global setting is enabled. By default, MVRP is disabled globally and on individual ports. When MVRP is disabled globally, all MVRP packets are forwarded transparently.
The following command enables MVRP globally on the switch:
enable mvrp
This command was first available in ExtremeXOS 15.3.
