Configures an existing local network login account.
user-name | Specifies the name of an existing local network login account. |
tagged | Specifies that the client be added as tagged. |
untagged | Specifies that the client be added as untagged. |
vlan_name | Specifies the name of the destination VLAN. |
vlan_tag | Specifies the VLAN ID, tag, of the destination VLAN. |
none | Specifies that the VSA 211 wildcard (*) is applied, only if you do not specify tagged or untagged. |
N/A.
Password of the local network login account.
Passwords are case-sensitive and must have a minimum of 1 character and a maximum of 32 characters.
You must create a local network login account before using this command. To create a local network login user name and password, use the following command:
create netlogin local-user user-name {encrypted} {password} {vlan-vsa [[{tagged | untagged} [vlan_name] | vlan_tag]]} {security-profilesecurity_profile}If the switch displays a message similar to the following:
* Switch # configure netlogin local-user purplenet ^ %% Invalid input detected at '^' marker.
You might be attempting to modify a local network login account that is not present or the switch, or you might have incorrectly entered the account name. To confirm the names of the local network login accounts on your switch, use the following command:
show netlogin local-usersThis command applies only to the web-based and MAC-based modes of network login. 802.1X network login does not support local database authentication.
You must have administrator privileges to use this command. If you do not have administrator privileges, the switch displays a message similar to the following:
This user does not have permissions for this command.Passwords are case-sensitive. Passwords must have a minimum of 0 characters and a maximum of 32 characters. If you attempt to create a password with more than 32 characters, the switch displays the following message after you re-enter the password:
Password cannot exceed 32 charactersUpdating the password.
Modifying destination VLAN attributes.
The following command updates the password of an existing local network login account:
configure netlogin local-user megtestAfter you enter the local network login user name, press [Enter]. The switch prompts you to enter a password; however, the switch does not display the password. At the prompt enter the new password:
password:After you enter the new password, press [Enter]. The switch then prompts you to re-enter the password:
Reenter password:You can add a destination VLAN, change the destination VLAN, or remove the destination from an existing local network login account. This example changes the destination VLAN for the specified local network login account:
configure netlogin local-user megtest vlan-vsa green
This command was first available in ExtremeXOS 11.3.
