This command has been replaced with the following command: disable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] health-check vccv .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Disables the VCCV health check feature on one or all VPLS instances on the local node.
| vpls_name | Identifies the VPLS for which health check is to be disabled. |
| all | Specifies that health check is to be disabled on all VPLS instances on the local node. |
Health check is disabled.
None.
The following command disables the health check feature on the VPLS instance myvpls:
disable vpls myvpls health-check vccv
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
