Disables the generation and processing of BOOTP packets on a VLAN to obtain an IP address for the VLAN from a BOOTP server.
| bootp | Disable BOOTP client. |
| ipv4 | IPv4 client. (default) |
| dhcp | Disable DHCP client. |
| ipv6 | IPv6 client. |
| vlan | Specify VLAN to configure BOOTP/DHCP client for. |
| vlan | Specifies a VLAN name. |
| all | Disables all VLANs. |
Disabled.
If the IPv4/IPv6 keyword is not specified, IPv4 is taken as default for the mentioned VLAN.
The following example disables the generation and processing of BOOTP packets on a VLAN named accounting:
disable bootp vlan accounting
The ipv4 and ipv6 keywords were added in ExtremeXOS 15.6.
