Configures an 802.1p priority to QoS profile mapping for the specified ports.
| dot1p_priority | Specifies the 802.1p priority value. The value is an integer between 0 and 7. |
| qosprofile | Specifies a specific QoS profile. The value range is QP1 to QP8. |
| ingress-meter | Ingress rate-limiter meter. |
| ing_meter | Ingress rate-limiter meter name. |
| none | Dot1p examination rule has no ingress-meter (default if ingress-meter is unspecified). |
The default mapping of each 802.1p priority value to QoS profile is shown in the following table.
| 802.1p Priority Value | ExtremeSwitching Series Switches Default QoS Profile |
| 0 | QP1 |
| 1 | QP1 |
| 2 | QP1 |
| 3 | QP1 |
| 4 | QP1 |
| 5 | QP1 |
| 6 | QP1 |
| 7 | QP8 |
An 802.1p priority value seen on ingress can be mapped to a particular QoS profile and with specific bandwidth management and priority behavior.
You must create the QoS profile first, using the create qosprofile [QP2| QP3 | QP4 | QP5 | QP6 | QP7] command, to map the 802.1p information to QoS profile 2 through 7.
You must create the QoS profile first, using the create qosprofile [QP2| QP3 | QP4 | QP5 | QP6 | QP7] command, to map the 802.1p information to QoS profile 2 through 6. You cannot create QP7 in a SummitStack.
The following commands reassign (from the default) the QoS profiles associated with 802.1p priority values 1 and 2:
# configure dot1p type 2 qosprofile qp2 # configure dot1p type 1 qosprofile qp3
The following examples use the ingress-meter option:
# configure dot1p type 1 qosprofile qp5 ingress-meter ingmeter0 # configure dot1p type 2 qp3 ingress-meter ingmeter2 # configure dot1p type 3 qp4
This command was first available in ExtremeXOS 11.0.
The ingress-meter, ing_meter, and none options were added in ExtremeXOS 16.1.
