clear esrp counters
clear esrp counters
Description
Clears the statistics gathered by ESRP for all ESRP domains on the switch.
Syntax Description
Default
None.
Usage Guidelines
Use this command to clear the state transition and the protocol packet counters gathered by ESRP.
The state transition count displays the number of times the ESRP domain entered the following states:
To display information about the ESRP domain, including the previously described states, use the show esrp { {name} | {type [vpls-redundancy | standard]} } command.
The protocol packet count displays the number of times ESRP, ESRP-aware, and ESRP error packets were transmitted and received.
To display information about the ESRP counters, use the show esrp {name} counters command.
The following command clears the statistics gathered by ESRP:
clear esrp counters
This command was first available in ExtremeXOS 11.0.
Platform Availability
