Shows information about all servers configured for Automation Edge remote VXLAN network identifier (VNI)-device databases.
| database | Shows database information. |
| database_name | Shows database information for the specific named database. |
N/A.
N/A.
The following example shows server information for all databases:
# show database
Retries : 3
Database Name
Server Port Flags
NewsroomNetwork1
2001:0db8:85a3:0000:0000:8a2e:0370:7334 5456 C----
CastleBlack 34344 D----
10.10.10.10 12345 C----
NewsroomNetwork2
3001:0db8:85a3:0000:0000:8a2e:0370:7334 5456 C----
EastWatch 34344 D----
10.10.10.12 12345 T----
Flags : (C) Connected, (D) Disconnected, (T) Timed out.
The following example shows server information for the database "NewsroomNetwork1":
# show database NewsroomNetwork1
Database : NewsroomNetwork1 Retry : 3
Server: 2001:0db8:85a3:0000:0000:8a2e:0370:7334 Port : 5456
Status: DOWN
Last connect : Tue Sep 10 20:22:48 UTC 2019
Last disconnect: Tue Sep 10 20:22:48 UTC 2019
# Disconnects : 2
Server: EastWatch Port : 34245
Status: UP
# Disconnects : 5
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
This command is available on the ExtremeSwitching 5520 platform.
