Displays IP statistics for the switch CPU for a particular VLAN.
| name | Specifies a VLAN name. |
| tunnel_name | Specifies a tunnel name. |
N/A.
This command only shows statistics of the CPU-handled packets. Not all packets are handled by the CPU.
The fields displayed in the show ipstats command are defined in the following tables.
| Field | Definition |
| Packets IN/OUT | Total number of IP packets received or transmitted on a VLAN router interface. |
| Octets IN/OUT | Total number of octets received or transmitted on a VLAN router interface. |
| Mcast packets IN/OUT | Total number of multicast packets received or transmitted on a VLAN router interface. |
| Bcast packets IN/OUT | Total number of broadcast packets received or transmitted on a VLAN router interface. |
| Errors IN/OUT | Total number of IP packets with errors received or transmitted on a VLAN router interface. |
| Discards IN/OUT | Total number of IP packets that cannot travel up to the CPU due to lack of buffer space. |
| Unknown Protocols IN/OUT | Total number of IP packets with unknown upper layer protocols received by the router interface. |
The following example displays IP statistics for the VLAN "accounting":
show ipstats vlan accounting
The ipv4 keyword was added in ExtremeXOS 11.2.
The VR option was removed in ExtremeXOS 30.1.
