unconfigure bootprelay dhcp-agent information policy
Description
Unconfigures the DHCP relay agent option (option 82) policy.
Syntax Description
Default
Replace.
Usage Guidelines
Use this command to unconfigure the policy for the relay agent.
The following example unconfigures the DHCP relay agent option 82 policy:
This command was first available in ExtremeXOS 11.1.
Platform Availability
