This command configures the T1 restart retransmit timer for one or all VLANs.
| vlan all | Specifies that the T1 restart timer configuration applies to all VLANs. |
| vlan_name | Specifies a VLAN to which the T1 restart timer configuration applies. |
| seconds | Specifies the T1 restart timer value. The range is 1 to 65535 seconds. |
| level [1 | 2] | Limits the configuration change to level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels. |
3 seconds.
If, after sending a restart request, the router process associated with this interface does not receive a restart acknowledgement and a CSNP within the period specified by this command, another restart request is sent.
The following command sets the T1 restart timer to 6 seconds on all level 1 VLANs:
configure isis vlan all timer restart-hello-interval 6 level 1
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
