disable mirror
disable mirror [mirror_name | all]
Description
Disables a mirror instance.
Syntax Description
mirror_name Specifies the mirror name.
all Specifies all mirror instance are deleted.
Default
Disabled.
Usage Guidelines
Use this command to disable mirrors. Disabling an instance only changes the state, its configuration remains as defined (a change from current operation, which loses some configuration parameters).
The following example disable a mirror instance named "mirror1" :
disable mirror mirror1
This command was first available in ExtremeXOS 15.3.
Platform Availability
