This command enables or disables statistics monitoring (byte/packet counters) on a Virtual Network remote endpoint.
| ipaddress | An existing interface IPv4 address. |
| vr | VR/VRF instance the IPv4 address is configured on. |
| vr_name | An existing VR/VRF name. |
| on | Enable statistics. |
| off | Disable statistics. |
Off.
The command applied on dynamic remote endpoint is not saved to the configuration. If you want it to be saved, convert the remote endpoint to static using the command create virtual-network remote-endpoint vxlan ipaddress ipaddress {vr vr_name}.
To enable statistics monitoring on an existing Virtual Network remote endpoint:
configure virtual-network remote-endpoint vxlan ipaddress 10.10.10.146 monitor on
This command was first available in ExtremeXOS 21.1.
This command is available on all Universal switches and stacks supported in this document.
