Disables the transmission of OSPFv3 SNMP notifications.
| ospfv3 | OSPFv3-related traps. |
The default is disabled.
The following example disables the transmission of OSPFv3 SNMP notifications:
disable snmp traps ospfv3
This command was first available in ExtremeXOS 22.1.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
